Location of output speed sensor VSS
2008 NISSAN PATHFINDER
200,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
MELISSASTN
I have looked everywhere and cannot locate the VSS output transmission speed sensor.
May 22, 2019 at 8:37 PM
SCGRANTURISMO
  • 4,897 POSTS
I have included the information you requested in the diagrams down below. It looks as if the Vehicle Speed Sensor is located in the transmission with a redundant system in the combination switch. Please go through the information and get back to us with what you find out. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Thanks,
Alex
2CarPros
May 22, 2019 at 10:15 PM
MELISSASTN
Thank you so much I cant believe this site is free.
May 23, 2019 at 3:17 AM
SCGRANTURISMO
  • 4,897 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Thanks,
Alex
2CarPros
May 23, 2019 at 6:40 PM
STETSONSNANA
Output speed sensor location I need to change it.
Dec 15, 2020 at 10:17 AM (Merged)
I am attaching the info on the speed sensor. This is a vehicle speed sensor also called the revolution sensor. I am attaching the location for it as requested.
Let us know if there is more info needed. Thanks
MSTREETT
Electrical problem 6 cyl Four Wheel Drive Automatic 113500 miles
I'm getting a trouble code that my vehicle speed sensor is malfunctioning. However, I can't seem to locate the speed sensor on the vehicle. I went to a Nissan dealer and they provided me with a diagram showing the speed sensor is located on the transfer case of the transmission (drivers side). However, I have looked all over and can't seem to find the sensor on the vehicle. Where is this sensor located? The model is SE and the engine size is 3.5L.
IMPALASS
  • 3,112 POSTS
Hello - VEHICLE SPEED SENSOR Removal & Installation 1. Remove bolt and Vehicle Speed Sensor (VSS). See Fig. 14 . Fig. 14: Locating Vehicle Speed Sensor Courtesy of NISSAN MOTOR CO., U.S.A.
https://www.2carpros.com/forum/automotive_pictures/248015_14_5.jpg
2. To install, reverse removal procedure. Install NEW "O" ring on VSS. Tighten bolt to specification. See TORQUE SPECIFICATIONS . The information is really slim
https://www.2carpros.com/forum/automotive_pictures/248015_208_1.jpg
I have attached one pic above and it looks like they also call it a Revolution sensor. Yellow and orange and possible a black wire. Check out the diagrams (Below) Please let us know what happens. Cheers
CARL44
Perfect thanks for the help this site rocks!
