It sounds like the mode door for the defrost is not functioning. Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Removal and Installation
1. Remove the Instrument Panel Cluster (IPC). For additional information, Refer to 413-01 .
2. Remove the 4 knee bolster bolts and the knee bolster.
3. Remove the 2 lower steering column shroud screws and the lower steering column shroud.
4. NOTICE: Do not press the brake pedal when removing or installing the speed control deactivator switch, as the switch will be damaged.
Remove the speed control deactivator switch.
- Rotate the speed control deactivator switch counterclockwise 45 degrees and remove the deactivator switch.
5. Detach the 3 wire harness-to-brake pedal bracket pin-type retainers from the top of the brake pedal bracket.
6. Disconnect the defrost/panel/floor mode door actuator electrical connector.
7. NOTE: The upper rear defrost/panel/floor mode door actuator screw can be accessed through the Instrument Panel Cluster (IPC) opening using a swivel-type socket and extension.
Remove the 3 defrost/panel/floor mode door actuator screws.
8. Remove the defrost/panel/floor mode door actuator.
9. To install, reverse the removal procedure.
10. NOTE: The purpose of the module actuator position calibration is to allow the HVAC module to reinitialize and calibrate the actuator stop points. To carry out calibration, carry out the following steps.
Remove Smart Junction Box (SJB) fuse 15 for at least one minute.
11. NOTE: When the ignition switch is switched to the ON position, the HVAC module will initialize and calibrate the actuators. Calibration of the actuators will take approximately 30 seconds.
Reinstall SJB (Smart Junction Box) fuse 15. Turn the ignition switch to the ON position and wait 30 seconds before verifying correct mode door operation.
Jun 11, 2019 at 8:02 AM
