Location of MAF sensor
2006 CHRYSLER SEBRING
156,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MICHAEL COWART
  • 9 POSTS
I am having trouble locating the MAF sensor. Please help me locate it.
Dec 18, 2019 at 7:00 AM
Good morning,
The car does not have a mass airflow sensor. It uses a MAP sensor in place. I attached a picture of the location for you.
What is the issue that makes you think you need a mass airflow sensor?
Dec 18, 2019 at 8:09 AM
MICHAEL COWART
  • 9 POSTS
The car is idling rough and when I hook up the PCV hose it shuts off.Without it hooked up it runs fine. The timing belt and water pump were recently changed. Just put a new throttle position sensor in and have a new PCV valve to install.The codes being thrown were mass air flow sensor,throttle position sensor and thermostat sensor with a random misfire.
Dec 18, 2019 at 9:18 AM
Okay, can you give me the code numbers so I can look them up and give you more information?
Dec 18, 2019 at 10:22 AM
MICHAEL COWART
  • 9 POSTS
I'm at work I can send them later today.
Dec 18, 2019 at 10:50 AM
MICHAEL COWART
  • 9 POSTS
I looked at another diagram on here and it is showing a mass air flow sensor by air pump motor and air pump relay. I'm lost.
Dec 18, 2019 at 10:59 AM
Okay, thanks.
Again, there is no mass air flow listed for your car in our information system.
Once I get the codes, I can further help.
Dec 18, 2019 at 11:51 AM
MICHAEL COWART
  • 9 POSTS
Okay.
Dec 18, 2019 at 1:14 PM
Keep me updated.
Dec 18, 2019 at 1:20 PM
HOOKS0061
Do I have a mass air flow sensor. I can't seem to locate it. I am having hesitation upon acceleration and was told to clean the sensor. Check air filter and use fuel injector cleaner. I have also changed my plugs and wires
Nov 16, 2020 at 6:43 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Sure here is a guide to help you get the job done with the location of the MAF in the diagrams below.
https://www.2carpros.com/articles/mass-air-flow-service
HOOKS0061
thanks docfixit, i see the mass air flow sensor but dont see where its located in the engine?
VEROANNLARA
Does my 128ci Dohc has a MAF sensor. Do you have labels diagrams for the vehicle?
Nov 16, 2020 at 6:44 PM (Merged)
CARADIODOC
  • 34,306 POSTS
Chrysler is the only manufacturer that has never needed or used a mass air flow sensor to make their engines run right on their domestic models. The main fuel metering calculations come from the MAP, manifold absolute pressure sensor. That is a fancy name for a vacuum sensor.
i was wondering cuz i looked everywhere to see if i could find the mass air flow or the vane air flow on my car could not find it nowhere can u tell me where it would be at please thank u cuz i get a code po106 i checked probable cuses where barometer/map,vaf dirty or defective vacumm hose off,or cracked or passage blocked engine mechanical timing conditio.checked all them except the maf sensor could not locate it please help thank you
DOCFIXIT
  • 18,828 POSTS
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_454.jpg
intake manifold
I AM TALKING ABOUT THE MAF SENSORNOT THE MAP SENSOR
DOCFIXIT
  • 18,828 POSTS
Car does not have MAF uses MAP
SEXYZ
I just changed the TPS sensor and pigtail and now I cant find the MAF sensor so I can clean it cause my car is still not running right. the idle is off and is hard to keep running without it stalling out
JDL
  • 16,098 POSTS
According to our database, you don't have a maf sensor, but, you do have a map sensor. Did you check for applicable codes? You should be able to get some codes by cycling the ignition switch. You turn key just till the dash lites come on, no further. Cycle the key on--off, on---off, on, then the mil on the dash starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
The basics for a rough idle,is to check for a leak of some kind, fuel--egr--vacuum, something like that. Go from there.
