Okay. Yes, the connector that is next to the blower motor is most likely the resistor. They call it a control module. So, if you have battery voltage getting to it then it is likely the issue.
There are two connectors for it, and I am attaching the info on this below.
Basically, you need to check the voltage getting to and what the speed control is showing. This will mean if the blower is not working then the resistor is the issue or the blower motor.
Have you put 12 volts to the blower motor and make sure it works?
Apr 25, 2022 at 9:16 AM
