Location of fuel filter?
2008 AUDI A6
109 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
QUA2468
  • 8 POSTS
I am having a problem locating my fuel filter. I located the fuel regulator underneath on passenger side and I am wondering if they are both combined into one. please help.
Nov 28, 2017 at 12:36 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Yes, you are correct. Fuel filter with pressure regulator. It is number three in this diagram. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Nov 28, 2017 at 5:45 AM
MSCHUPP
Where is the fuel filter located on the A6 2.7?
Sep 24, 2020 at 10:13 AM (Merged)
Servicing fuel filter Fuel Filter Located Behind Cover
https://www.2carpros.com/forum/automotive_pictures/12900_f1_16.jpg
Remove 2 bolts (arrows) for fuel filler neck underneath rehousingg liner. WARNING: Fire Hazard. Do not smoke, work near heaters or have anything in the area that could ignite the fuel or fumes. Fuel supply lines are under pressure! Before loosening any lines, cover the connection with a rag. Release the pressure by slowly separating the connection.
https://www.2carpros.com/forum/automotive_pictures/12900_f2_16.jpg
Fuel Filter With Cover Removed Mark supply line -3-, return line -2- and vent line -1- and disconnect https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Sep 24, 2020 at 10:14 AM (Merged)
BANDANA
I need to know the location of my fuel filter for my car listed above it is the Quattro model.
Sep 26, 2020 at 10:38 AM (Merged)
It is under the car near the tank. You will need a jack to get to it.
Here is a guide so you can do the job safely:
This guide will give you an idea of what you are in for.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Below are some diagrams of the job being done on your car.
MITAAJIT
Where is the location of the fuel filter in an Audi A6 Year 1998
STEVEW84
  • 673 POSTS
Fuel filter is located in front right outside at fuel tank
MITAAJIT
Thank you Steve
So the car has to be on a lift and i guess the filter is easily accessible and can be changed using regular tools - meaning no specialized tools
Thanks again
STEVEW84
  • 673 POSTS
it would be easier with a lift, but you should be able to do it one the ground. you might need a special torx to get the fuel filter clamp off, but regular hands tools should be ok.
TERRIBLE HERBST
  • 6 POSTS
Right next to the top of the air filter box, about the size of an oil filter. Real easy job, simply loosen 2 nuts, replace filter, tighten up nuts.
