Location of evaporator housing drain tube
2001 FORD E-SERIES VAN
150,000 MILES
REBCONR
I have a 2001 E-150. Water is accumulating in the evaporator housing and running into the passenger floorboard. It is clean water, no other fluids. I am pretty sure the drain tube is clogged, but I have looked and just cannot find it.
Sep 8, 2018 at 2:53 PM
Lucky you, we just finished this video that shows the AC drain location. You must be living right. :)
https://youtu.be/q9_MZiS2_NE
Sep 8, 2018 at 5:56 PM
REBCONR
Thanks, but I cannot find the tube. I felt all around the evaporator housing, even looked at pictures of replacement parts, and there is no hole in it. The cover on the heater core has a 1" hole at the bottom that comes back through the firewall. Would that be it? I tried cleaning it out with a coat hanger and air compressor, but got no debris or water out of it.
Sep 11, 2018 at 8:06 AM
Yes, it sounds like you found it, if no water comes out it not plugged is it possible the tube feel off. Can you upload a video or pictures so I can see what you are looking at?
Sep 11, 2018 at 12:24 PM
