Where is the crankshaft located?
2009 SATURN VUE HYBRID
150,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
CGOENS
I am needing to know the location for the vehicle listed above.
Oct 20, 2024 at 12:57 PM
The engine crankshaft is in the center of the engine block down low. Check out the images (below). Let us know if you need anything else.
Oct 20, 2024 at 1:24 PM
CGOENS
Is that on top of the transmission next to the rack and pinion or back behind the exhaust manifold? Do you have a key for the diagram you sent before?
Oct 22, 2024 at 1:08 AM
Are you talking about the crankshaft angle sensor? If so this is the location of the sensor. Check out the images (below). Let us know what you find.
Oct 22, 2024 at 10:31 AM
