Where is the camshaft sensor located?
2018 FORD MUSTANG
60,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
MICHAEL5.0
  • 5 POSTS
When the car gets to a full stop it sounds like it's choking and it turns off a lot when i come to a complete stop. And I'm very positive it's the camshaft sensors from what i believe but am having a very hard time finding the location of my model.
Mar 5, 2024 at 7:16 PM
They hid them. Honestly, you have to take the engine appearance cover from the top of the engine to find them. Also, if your vehicle has the cross brace that runs from the top of the engine to the strut towers, that needs to be removed as well.
As far as the sensors are concerned, there are a total of four, two on each side (intake cam and exhaust cam). If you look below, I attached the directions for removing and replacing them. Take a look and let me know if you have other questions. Note: They are mounted at the top rear of the valve covers.
See pics below.
Mar 5, 2024 at 8:38 PM
MICHAEL5.0
  • 5 POSTS
So, i bought 4 sensors from ford but they weren't specified like intake and exhaust cam they just gave me 4 cam sensors. i went ahead and changed them out, but it didn't resolve the issue. Do you have any idea what could be wrong with it? When i come to a red light or stop the car sounds like it's choking and the RPMs drop and go high, and the car shuts off.
Mar 6, 2024 at 9:49 AM
Let's see if we can figure this out. First, have you tried retrieving diagnostic trouble codes? If you have, let me know what they are.
Next, what you described could be a few things. For example, an engine vacuum leak can cause the idle speed to jump around or even cause the engine to stall. It wouldn't hurt just check.
Here is a link that explains how it's done:
Next, there are several different sensors that are used to maintain the engine's idle speed. If one of them is causing an issue, it should show up if you scan the computer. Often times a parts store will do a general scan at no charge. You may want to consider having that done if the check engine light is on.
Here is a link that shows how to scan all modules (can-bus):
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Let me know if there are codes, any vacuum leaks, or any other issues. Also, let me know if you have ever experienced the engine stalling and not restarting for a period of time.
Mar 6, 2024 at 6:52 PM
