Please be aware that there are two temperature actuators on this vehicle. I will provide the directions for the passenger side, but before you replace it, just confirm it is the correct one. Simply place your hand on it and you should feel the thumping.
To get you started, here is a link that explains in general how one is replaced:
Here are the directions specific to your vehicle (right side):
____________________________________________
2015 Ford Truck Expedition 4WD V6-3.5L Turbo
Temperature Blend Door Actuator - Passenger Side
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Removal and Replacement Temperature Blend Door Actuator - Passenger Side
TEMPERATURE BLEND DOOR ACTUATOR - PASSENGER SIDE
412-01 Climate Control 2015 Expedition, Navigator
REMOVAL AND INSTALLATION
Temperature Blend Door Actuator — Passenger Side
Removal
Remove the Audio Front Control Module (ACM) . Refer to, Section 415-00A , Section 415-00B , Section 415-00C or Section 415-00D .
Lower the glove compartment.
While pushing the glove compartment door tabs, position the glove compartment downward.
pic 1
NOTE: The forward passenger temperature blend door actuator screw can be removed with a combination wrench. With one hand working through the ACM opening, hold the top end of the combination wrench. With the other end of the combination wrench pointing away (toward the right front corner of the vehicle), and with the other hand working through the glove compartment opening, the combination wrench can be manipulated.
Remove the passenger temperature blend door mode door actuator.
Disconnect the passenger temperature blend door mode door actuator electrical connector.
Remove the screws and the passenger temperature blend door mode door actuator.
pic 2
Installation
NOTICE: The ignition key must be off when replacing the actuator. Energizing the actuator before installation will cause the part to become positioned incorrectly and proper orientation will be lost. Incorrect actuator operation will result.
To install, reverse the removal procedure.
NOTE: The purpose of the module actuator position calibration is to allow the Heating Ventilation Air Conditioning (HVAC) module to reinitialize and calibrate the actuator stop points. To carry out calibration, carry out the following steps.
____________________________________________________________________
To recalibrate the actuator, follow these directions.
Remove Body Control Module (BCM) fuse 46 (10A) for at least one minute.
NOTE: When the ignition switch is switched to the ON position, the HVAC module will initialize and calibrate the actuators. Calibration of the actuators will take approximately 30 seconds.
Reinstall BCM fuse 46 (10A). Turn the ignition switch to the ON position and wait 30 seconds before verifying correct mode door actuator operation.
Dec 11, 2019 at 8:21 PM
