I am having trouble locating the BCM on my vehicle listed above, would you have a diagram available to share? Thank you
Nov 24, 2024 at 12:28 PM
CERTIFIED EXPERT
This is because they call the BCM the TIPM and it is easy to replace because it itself learns so there is no programming necessary. Check out the images (below). Let us know if you need anything else.
Nov 24, 2024 at 1:16 PM
ICUNURSE28
MEMBER
Thank you. Is there a way to do a hard reset on this part to see if this fixes the problems before we replace it?
