Location of assembly speed sensor
2013 HONDA ACCORD
90,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
CAMERONLEON
Scanner shows up a problem with speed sensor (PO717).
Part number 28820-rj2-003
Cannot find where is located. Removed a sensor located on top back of CVT but it does not look like the replacement part.
If it is an easy to reach location, I just need to know where is it. If I need to remove other parts, I need basic instructions.
Sep 2, 2017 at 2:04 PM
HARRY P
  • 2,292 POSTS
It should be under the battery tray. I will include some instructions in the images.
Sep 2, 2017 at 7:09 PM
STEVE W.
  • 15,113 POSTS
Because it is under the battery I would check the wiring VERY close. Even a single drip of acid into a connector would be enough to corrode the connection and set that code. Replace the part and the code returns because of the corrosion.
Sep 5, 2017 at 5:14 AM
