You selected the 4WD so I assume you have the AWD model which means you have the 2.4L turbo? It doesn't appear to matter as it results to the throttle position sensor because your vehicle has what is called a throttle unit. Then the ECM uses the accelerator pedal position sensor for both the pedal and throttle position. Take a look at where it says that the pedal and throttle are treated like they are mechanically connected.
Let us know what the issue is that you are dealing with and we can see what other info you may need. Thanks
Nov 14, 2020 at 7:44 AM
