Where is the fuel pump control module located?
2011 LINCOLN MKZ
110,000 MILES • V6 • AUTOMATIC
BR8KN
I need to know where the fuel pump control module is located on or in my car so I can replace it with the part that I got.
May 13, 2024 at 5:16 PM
It could be the fuel pump is out but let's give it a go, fuel pump control module is located behind the rear seat in the trunk, but I need to say the fuel pump control wiring does not show a fuel pump control module, only an inertia switch and relay. Here are the wiring diagrams so you can see. Check out the images (below). Please upload pictures or videos in your response to any problems so we can see what to help you with.
May 14, 2024 at 11:50 AM
BR8KN
If I may I would like to tell you what it's doing and not doing. This issue with my wife's 2011 Lincoln MKZ started a little over a month ago. When it was idling the RPMs would drop briefly and then go back up to normal and then it would drop down again briefly and go back up to normal and it kept doing that so I replaced all the fuel injectors I replaced the spark plugs and the coil pack at first it seemed like it was running a lot better and then it wouldn't start the first time you turned over the key it would just crank and then you turn off the key and then you tried it again and then it would start and did that for a while and then about 2 weeks after this started happening we were at Burger King and it just died out wouldn't start back up it would just crank so I had it towed to my house now it just cranks and won't start so I took out the air cleaner and sprayed the carburetor cleaner in it and left it off try to start it and it started right up it ran for about 30 minutes and then it just like choked itself out it just shut off and now it's back to not starting again just cranking and I don't know what the heck the problem is but it's really frustrating.
May 16, 2024 at 8:32 AM
This sounds like a typical fuel pump failure, have the car in a quiet place, turn the ignition on without cranking the engine over to see if you hear the fuel pump run, if not the pump has probably gone bad but to be sure you can check for power at the inertia switch.
If it has power the pump is bad, here is the location of both parts so you can fix the problem. The inertia switch should have power at both wires when cranking. Check out the images (below). Please let us know what happens.
May 16, 2024 at 12:03 PM
