Code P0190, where is the Fuel Rail Pressure Sensor located?
1999 MERCURY COUGAR
156,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
AL-WITH-A-CAR
  • 11 POSTS
I have the error code "P0190 Fuel Rail Pressure Sensor Circuit Bank 1" but the manual I have seems to only mention the older "Fuel Pressure Regulator". Could someone provide me with the updated diagrams and instructions for locating and replacing the Fuel Rail Pressure Sensor?
Jun 8, 2025 at 2:39 PM
It says the sensor is on the top left rear of the engine which should be on or near the fuel rail. This is what it looks like. Check out the images (below). Let us know if you need anything else.
Jun 8, 2025 at 3:02 PM
AL-WITH-A-CAR
  • 11 POSTS
So from my understanding, I may need a specialized tool to disconnect it? If this is true, could you perhaps link one or say if there's a more common tool that could be substituted?
Jun 9, 2025 at 1:42 PM
If there is a fuel line connected to it then yes you need to remove it, this video can help:
https://www.youtube.com/watch?v=Boi0DPXVHbM
If not and it is bolted to the fuel rail you will be okay to remove it.
Jun 9, 2025 at 4:40 PM
AL-WITH-A-CAR
  • 11 POSTS
Do you know where I might buy the fuel-line disconnection tool for cheap?
Jun 9, 2025 at 5:32 PM
Here is a great set for $24.00:
https://amzn.to/43TIa7F
Let us know how it goes.
Jun 10, 2025 at 11:48 AM
AL-WITH-A-CAR
  • 11 POSTS
So finally got the part, replaced it, and now the car has a constant p1000 code. It cranks but won't start.
Jul 16, 2025 at 5:27 PM
So you replaced the part and now it wont run, did it run before? If so it sounds like you have a defective part.
Jul 17, 2025 at 10:04 AM
AL-WITH-A-CAR
  • 11 POSTS
Last time I worked on it, (before replacing the part) it started after about 3 tries, ran for a few minutes, then died and refused to start again. Although it of course did not have the p1000 code until after this part replacement.
Jul 17, 2025 at 5:43 PM
Does it have any other codes besides the p1000? You could have a defective PCM. Please go over this guide
https://www.2carpros.com/articles/scan-test-is-incomplete-p1000
Jul 18, 2025 at 9:05 AM
AL-WITH-A-CAR
  • 11 POSTS
It does not have any further codes besides the p1000 no. As for symptoms, the engine when turning over sounds as if it may not be receiving fuel? I cannot accurately listen for the fuel pump when inserting the key either, due to the CD player making a 'fun' noise for a while after insertion of the ignition key. The last symptom I can remember is the low battery light being on the entire time, as I had to try to jump the car with another running vehicle due to its battery being flat out dead and not holding charge.
Jul 18, 2025 at 2:11 PM
The CD player can make the battery go dead fyi. Lets use this video to show you how to see if the fuel pump is working or not.
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
Jul 19, 2025 at 9:32 AM
AL-WITH-A-CAR
  • 11 POSTS
So the engine begins to start and runs for as long as starter is sprayed into the intake (a few seconds). This would mean the issue is in the fuel delivery correct? If this is the issue, it's likely the fuel pump yes?
Jul 28, 2025 at 4:26 PM
Yes, but I would check the inertia switch as well which is at the right side kick panel. Check out the images (below). Please let us know what happens.
Jul 28, 2025 at 5:20 PM
AL-WITH-A-CAR
  • 11 POSTS
Okay, what does that switch perform, and where precisely is the panel located?
Jul 28, 2025 at 5:36 PM
This switch is a safety feature, it cuts power to the fuel pump when in an accident. Push the button on top of it to reset it. It is behind the right side kick panel.
Jul 29, 2025 at 10:26 AM
AL-WITH-A-CAR
  • 11 POSTS
Where exactly is that located?
Jul 29, 2025 at 4:49 PM
It is behind the right side kick panel. Have you removed the panel? The panel is on the right side footwell rear the door
Jul 30, 2025 at 9:27 AM
AL-WITH-A-CAR
  • 11 POSTS
So, if it's not the switch, what next?
Jul 30, 2025 at 1:28 PM
