Locate and Replace Washer Fluid Pump
2012 FORD F-150
28,600 MILES • V8 • 4WD • AUTOMATIC
KURTANDCARLA
I'm trying to locate and replace the washer fluid pump. I was told I would need to remove passenger side headlight. I'm concerned about being able to properly realign that. Any other options?
Feb 29, 2016 at 1:17 PM
HMAC300
  • 48,601 POSTS
you don't have to worry about realigning if you don't mess with adjustment screws. see pics then pull 3 bolts for headlight and disconnect electrical. do not turn on washer pump until fluid is in jar.
Feb 29, 2016 at 4:04 PM
