Locate a part
2004 FORD F-150
250,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
EASTTOSAYTHELEAST01
I need to know where the IAC valve is exactly.
May 11, 2019 at 6:47 PM
EASTTOSAYTHELEAST01
This is a 03/04 Ford f150 5.4 Triton.
May 11, 2019 at 6:49 PM
Welcome to 2CarPros.
I'm not sure if you mean an 03 or an 04. I will provide info on both. First is related to the 04.
The IAC is part of the throttle body assembly. I attached the only pic I could find that may help you. The IAC valve assembly is not adjustable and can not be cleaned.
I don't know if you need them or not, but here is an extensive diagnostic flow chart regarding pinpoint testing of the IAC. All attached pics correlate with these directions.
____________________________________________
KE: Idle Air Control (IAC) Valve
KE: Introduction See: Computers and Control Systems > Pinpoint Tests > KE: Idle Air Control (IAC) Valve - Introduction
KE1 IDLE CONCERNS OR STALLS: RUN THE KOER SELF-TEST AND OUTPUT THE CMDTCS
Note:The Symptom Charts indicate there was no change in idle quality when the IAC valve was disconnected.
- CHECK the air inlet for plugging or a stuck IAC pintle.
- Repair as necessary.
- Retrieve all continuous memory DTCs.
- Carry out the KOER self-test.
- If unable to carry out the KOER self-test, go to the next diagnostic step.
Are any of the following DTCs present: P0505, P0511 or P0506?
Yes
- Key in OFF position.
- GO to KE2
No
- The IAC system is OK. Return to Section 3, Symptom Charts. See: Computers and Control Systems > Symptom Related Diagnostic Procedures
KE2 DTCS P0505, P0506, P0511, P1504 OR P1507: (OR STARTS ONLY AT PART THROTTLE) CHECK THE VPWR VOLTAGE TO THE IAC VALVE
Note:If EGR DTC P0402 was output during the self-test, diagnose it first before continuing with this pinpoint test.
- IAC Actuator connector disconnected.
- Key in ON position.
- Measure the voltage between:
picture 1
Is the voltage greater than 10.5 V?
Yes
- GO to KE3
No
- Key in OFF position. REPAIR the open circuit.
KE3 CHECK THE RESISTANCE OF IAC VALVE
- Measure the resistance between:
picture 2
Is the resistance between 6 ohms - 15 ohms?
Yes
- GO to KE4
No
- INSTALL a new IAC Valve.
KE4 CHECK THE IAC VALVE FOR AN INTERNAL SHORT TO THE IAC CASE
picture 3
Is the resistance greater than 10K ohms?
Yes
- GO to KE5
No
- INSTALL a new IAC actuator.
KE5 CHECK THE AIR INLET FOR PLUGGING OR A STUCK IAC PINTLE
- INSPECT the entire intake air system for debris, blockage or other damage.
- Remove and inspect the IAC valve and check the pintle movement. Check the air tubes (if equipped) for blockage or damage.
- Remove and inspect the air cleaner element for excessive dirt.
Is the IAC valve and intake air system OK?
Yes
- Restore the inlet air system.
- GO to KE6
No
- INSTALL a new IAC valve, or REPAIR the air inlet as necessary.
KE6 CHECK FOR INLET AIR LEAKS
- Key on engine running.
- With the engine running at idle, listen for vacuum leaks.
- INSPECT the entire air intake system from the mass air flow (MAF) sensor to the intake manifold for leaks such as:
- Damaged or loose IAC air tubes.
- Cracked or punctured intake air tube.
- Loose intake air tube at the air cleaner housing or throttle body.
- IAC valve or gasket seal.
- EGR valve gasket seal.
- Vacuum supply connector and hose.
- PCV valve, connectors and hoses.
Are any leaks detected in the above areas?
Yes
No
- GO to KE7
KE7 CHECK THE IAC CIRCUIT FOR AN OPEN IN THE HARNESS
Note:REFER to the PCM connector pin numbers in the beginning of this pinpoint test.
- PCM connector disconnected.
picture 4
Is the resistance less than 5 ohms?
Yes
- GO to KE8
No
- REPAIR the open circuit.
KE8 CHECK THE IAC CIRCUIT FOR A SHORT TO POWER IN THE HARNESS
picture 5
Is the voltage less than 1 V?
Yes
- GO to KE9
No
- Key in OFF position. REPAIR the short circuit.
KE9 CHECK THE IAC CIRCUIT FOR A SHORT TO GROUND IN THE HARNESS
- Diagnostic tool connector disconnected.
picture 6
Yes
- GO to KE10
No
- REPAIR the short circuit.
KE10 VERIFY THE DTC
Is DTC P0511 or P1504 present in continuous memory or from the KOER self-test?
Yes
- INSTALL a new PCM.
No
- GO to KE11
KE11 CHECK THE IAC SIGNAL FROM THE PCM
- PCM connector connected.
- IAC Actuator connector connected.
Note:If stalling occurs, place a shim under the hard stop screw to maintain idle conditions.
- Access the PCM and monitor the RPM PID.
- Access the PCM and monitor the IAC PID.
- With the engine at normal operating temperature, closed throttle and all accessories off, the IAC duty cycle should be between approximately 22% and 65%.
- Slowly increase the engine speed to 3,000 RPM and return to closed throttle. (Note: If closed throttle RPM is significantly higher than normal, ignore this step).
Is the duty cycle between 22% - 65%?
Yes
- GO to KE12
No
- Key in OFF position. INSTALL a new IAC actuator.
KE12 VERIFY THE DTC
Is DTC P0506, P0511, P1504 or P1507 present in continuous memory or from the self-test?
Yes
- GO to KE18
No
- INSPECT the throttle body for damage. REPAIR as necessary. If OK, INSTALL a new IAC actuator.
- RESET the keep alive memory (KAM). REFER to Section 2, Resetting The Keep Alive Memory (KAM) See: Computers and Control Systems > Diagnostic Trouble Code Tests and Associated Procedures > Resetting The Keep Alive Memory (KAM).
KE13 DTCS P0507 OR P1506: CHECK FOR INLET AIR LEAKS
Yes
No
- GO to KE14
KE14 CHECK THE EVAP SYSTEM FOR A STUCK OPEN VALVE
- Disconnect the hoses at the EVAP canister purge valve or the VMV.
- Connect a hand vacuum pump at the fuel vapor-to-EVAP canister port on the EVAP canister purge valve (VMV).
picture 7
- Apply 53 kPa (16 in-Hg) of vacuum to the EVAP canister purge valve (VMV).
Does the EVAP canister purge valve (VMV) hold a vacuum for at least 20 seconds?
Yes
- Reconnect all hoses.
- GO to KE15
No
- INSTALL a new EVAPCP valve.
KE15 CHECK THE IAC VALVE FOR CORRECT FUNCTION
- Bring the engine to normal operating temperature.
- Transmission in PARK or NEUTRAL.
- Disconnect the IAC Valve.
Does the RPM drop or the engine stall?
Yes
- GO to KE16
No
KE16 CHECK THE IAC CIRCUIT FOR A SHORT TO GROUND IN THE HARNESS
picture 8
Yes
- GO to KE17
No
- REPAIR the short circuit to GND.
KE17 VERIFY THE SYMPTOM
Is a fast idle symptom currently present?
Yes
No
- GO to KE18
KE18 CHECK THE IAC SYSTEM FOR AN INTERMITTENT OPEN OR SHORT
- Access the PCM and monitor the IAC and RPM PIDs.
- Observe the PIDs while completing the following at idle:
- Lightly tap on the and wiggle the harness connector to simulate road shock.
- Grasp the vehicle harness closest to the IAC valve. Shake and bend a small section of the harness from the IAC to the dash panel and from the dash panel to the PCM.
Do the IAC or RPM PIDs suddenly change in value, indicating a fault?
Yes
- ISOLATE the fault and REPAIR as necessary.
No
- GO to KE19
KE19 VERIFY THE SYMPTOM
Is an idle quality, starting or stalling symptom currently present?
Yes
No
- Concern is elsewhere. RETURN to Section 3, Symptom Charts for further direction. See: Computers and Control Systems > Symptom Related Diagnostic Procedures
______________________________________________
Next, I will review the 2003.
Again, the IAC is located on the throttle body. Here are directions for removal and replacement. The location is indicated in the directions. The remaining 4 pics correlate with these directions.
PROCEDURES
REMOVAL
1. Disconnect the battery ground cable.
picture 10
2. Remove the bolts and the accelerator control splash shield.
picture 11
3. Remove the Idle Air Control (IAC) valve electrical connector.
picture 12
4. Disconnect the throttle bypass hose.
picture 13
5. Remove the bolts and the IAC valve.
INSTALLATION
1. To install, reverse the removal procedure.
Let me know if this helps. Also, if you let me know the symptoms and if there are any codes, I may be of more help.
May 11, 2019 at 7:22 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I'm not showing an IAC valve on that motor however, it does show An Electronic Throttle Control Motor. I've attached a picture below and circled in red.Hope this helps and thanks for using 2CarPros.
Danny-
May 11, 2019 at 7:28 PM
