Loading up on fuel at idle it will not hold steady speed
1995 CHEVROLET MONTE CARLO
200,000 MILES • 3.1L • V6 • FWD • AUTOMATIC
HOLLYCLEND
Could this cause cracked spark plugs? It is using lots of gas. Took off catalytic converter and muffler. Fuel tank has a leak. Could this be a cause of the problem? Loading hill. Fuel and backfiring. The catalytic converter must have broken off and plugged muffler, because while driving it exploded the muffler now car does not run good at all. Could the compression that was built up from clogged muffler have blown? A head hassled when it exploded?
Jan 28, 2017 at 12:45 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge first, auto parts rent it. See link.
Jan 28, 2017 at 6:57 AM
