recorded live data from my truck does anything look of concern or faulty/bad
From reading this for i see high idle and maybe o2 sensor is bad on bank 2 side? Also, DTC codesp030, p0306, and p0174 misfire and bank 2 lean cylinder 1 and 6 misfire and think the o2 sensor may be faulty unsure also i did do a slight rev in that live data in the begin ish again thank you so much for your help.
Live Data
Numbers of DTCs 3
Fuel system 1 status--
Fuel System 2 status--
Calculated Load Value(%)18.0
Engine Coolant Temperature(°C)59
Short Term Fuel Trim -Bank 1(%)-3.9
Long Term Fuel Trim - Bank 1(%)5.5
Short Term Fuel Trim -Bank 2(%)-3.9
Long Term Fuel Trim - Bank 2(%)23.4
Engine RPM(rpm) 884
Vehicle Speed Sensor(km/h)0
Ignition Timing Advance for #1 Cylinder(°)6.0
Intake Air Temperature(°C)15
Air Flow Rate from Mass Air Flow Sensor(g/s)10.02
Absolute Throttle Position(%)15.7
Commanded Secondary Air StatusOFF
Location of Oxygen SensorsB1S12--B2S1---
Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.785
Short Term Fuel Trim Bank 1-Sensor 1(%)-5.5
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.100
Short Term Fuel Trim Bank 1-Sensor 2(%)N/A
Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.865
Short Term Fuel Trim Bank 2-Sensor 1(%)-4.7
OBD requirements to which vehicle is designedOBDII
Live Data
Numbers of DTCs 3
Engine RPM(rpm) 884
Jan 25, 2025 at 11:28 AM
