The reason for the repair. The shifter cable bushings needs to be replaced but these cables can’t replace the bushings the whole cable but its no longer available discontinued. In the meantime the grinding of the gears and eventually couldn’t shift into any gear. If you can provide taking apart where the cables are popped off the transmission and the linkage below where the shifter cables are pryed off the housing.
Aug 4, 2025 at 10:16 AM
