CAR WILL NOT SHIFT INTO PARK
LINCOLN TOWN CAR
VPHINES50
I HAVE 1991 LINCOLN TOWNCAR WITH ABOUT 100K MILE A V8 THAT WILL NOT SHIFT TO PARK I HAD TO PUT IT IN NEUTRAL TURN THE CAR OFF PUT THE EMERGANY BRAKES WHAT DO YOU THINK IT MAY BE
Nov 26, 2007 at 8:19 PM
BMRFIXIT
  • 19,053 POSTS
[quote:d808619564="vphines50"]I HAVE 1991 LINCOLN TOWNCAR WITH ABOUT 100K MILE A V8 THAT WILL NOT SHIFT TO PARK I HAD TO PUT IT IN NEUTRAL TURN THE CAR OFF PUT THE EMERGANY BRAKES WHAT DO YOU THINK IT MAY BE[/quote:d808619564]
Check the linkage above brake paddle on the steering column it has two screws and they may be loose
Also check if the shifter tube is broken
Check shifter cable
Nov 26, 2007 at 8:53 PM
