1998 Lincoln Town Car
1998 LINCOLN TOWN CAR
JBLU069
1998 Lincoln Town Car V8 212000 miles
every three or four months i have to replace my windshield wiper motor _ i have done this at least 4 times. do you have any suggestions
Nov 18, 2008 at 8:25 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
if the voltage going to the motor is correct, then i would be checking for a faulty regulator pivot that may be over loading the motor, start there.
mark (mhpautos)
Nov 18, 2008 at 8:27 PM
MHPAUTOS
  • 31,937 POSTS
The regulator is the section under the screen that the motor drives to operate the wipers, it connects the motor to the 2 wiper blades.
mark.
Nov 18, 2008 at 8:43 PM
C21 CT AGENT
Have you checked UNDER the Wiper motor itself in that plastic frame unit its bolted to ? There is a WATER DRAIN there . If its plugged your electric motor will be sitting in a pool of water after a rain.
The opening is the size of a Quarter and is front facing on the side of the plastic frame unit so it will be easy to tell if its filled with leaves or gunk once you have the wiper motor out. IF you dont see said opening then IT IS :)
This is my bet as I had same situation . The water would slowly drain but oneday it plugged solid and I found it.
I quick test with a garden hose or a quart of water from a mop bucket poured near the wiper motor to see if it drains fast will be all the test you need. should be quick with a quarter size hole opening that it has. Use care of course not to intentionaly get the wiper motor wet.
Hope this helps
Ron
Feb 11, 2009 at 8:58 PM
