1997 Lincoln Town Car DTC codes
1997 LINCOLN TOWN CAR
RATHMANN7
Electrical problem
1997 Lincoln Town Car Two Wheel Drive Automatic 122300 miles
Looking for possible fixes for code P0430, efficiency below threshold in catalyst system; and P0442, small leak for evaporative emission system
Nov 28, 2009 at 4:06 PM
RICKMAR
  • 170 POSTS
OBD-II P0430
Causes:
A code P0430 may mean that one or more of the following has happened:
* The catalytic converter is no longer functioning properly
* An oxygen sensor is not reading (functioning) properly
* There is an exhaust leak
Possible Solutions:
First, inspect for exhaust leaks.
Next step is to measure the voltage at the oxygen sensor on Bank 2.
In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
OBD-II P0442
Causes
A code P0442 most likely means one or more of the following has happened:
* A loose or improperly affixed "gas" cap
* A non-conforming gas cap (i.e. not factory/original brand)
* A small leak/hole in a fuel vapor hose/tube
* Other small leak in EVAP system "Vapor Canister Purge Valve"
* Faulty vent o-ring seal
Possible Solutions
With a P0442, the most common repair is to:
* Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
* Otherwise, replace the gas cap, or
* Inspect the EVAP system for cuts/holes in tubes/hoses.
* Faulty Vapor Canister Purge Valve.
* ONE TIME I WENT FOR THE MOST EXPENSIVE PART, THE "VAPOR CANISTER PURGE VALVE". IT TOOK CARE OF IT. I PULLED IT OFF A CAR IN THE JUNK YARD (CAN'T BEAT THE PRICE)!!
SOMETIMES IT IS JUST A GAS CAP!!
You can pull a purge valve off of a car in the Junk or Salvage yard if you have one near by to save some money.
I hope this information helped.
Good Luck;
Rick
Nov 28, 2009 at 11:46 PM
