engine runs but won't idle
1996 LINCOLN TOWN CAR
JRCHILDS
  • 4 POSTS
engine starts and runs good but dies at idle. adjusted idle screw about an eighth of an inch and motor continued to run. is there a idle switch or something that has gone bad?
Sep 9, 2010 at 6:06 AM
WRENCHTECH
  • 20,761 POSTS
You cannot adjust that screw. That is just a base idle stop and will mess everything up if adjusted wrong. The idle is not adjustable on this engine and you likely have a bad IAC or EGR valve but at this point your going to have to get a shop to set the base idle stop correctly. This guide can help us fix it.
https://www.2carpros.com/articles/stall-at-idle
May 5, 2021 at 1:18 PM
