1994 Lincoln Town Car Rear Brake Line Replacement
1994 LINCOLN TOWN CAR
80,000 MILES • V8 • 2WD • AUTOMATIC
WIZNVIC
The metal hydraulic brake lines that run to the rear wheels must be replaced. What must be done in order to get to the connection point at the front end of the line? When looking up at this area from under the car you can hardly see it much less get a line wrench on the fittings. Would removing the inner fender panel help?Thanxs in advance for any help.
Jan 30, 2010 at 7:49 AM
SCOTTY DEE
  • 592 POSTS
With just the wheel and tire off, you should be able to reach the union at the center of the rear axle. Is that what your needing?
Jan 30, 2010 at 5:01 PM
WIZNVIC
Not really, I have no problem with rear of the line access. What I have no idea how to get to is the front connection of the line. From under the car you can see it but can't reach it. I need to know what I have to remove to get to the distribution block where the line ties into.
Jan 30, 2010 at 5:09 PM
SCOTTY DEE
  • 592 POSTS
Do you mean at the master cylinder? Or the combination valve?
Jan 30, 2010 at 5:14 PM
WIZNVIC
The combination valve, the line from the master cylinder on down is OK.
Jan 30, 2010 at 6:32 PM
SCOTTY DEE
  • 592 POSTS
Do you have access to a lift?
Jan 30, 2010 at 6:45 PM
JKBOYZ
Well... 8 years later and I have the same question as WIZNVIC on 1994 Lincoln Town Car. You can barely see the distribution block where the brake lines tie into. Looked at removing the inner fender liner but way too much electrics are attached and difficult removal anyway since everything rusted. Appreciate help if anyone knows whether going at it from the top and removing master cylinder and booster is the way to go. I don't see any way to access brake line fittings from bottom up.
Dec 26, 2018 at 7:30 AM
DANNY L
  • 5,648 POSTS
Hello
You've attached a question to one that is years old. You need to start a new question and be sure to include your vehicle information.Here is the link and thanks for using 2CarPros.
Danny-
Dec 26, 2018 at 1:35 PM
