1994 Lincoln Town Car car will not stay running
1994 LINCOLN TOWN CAR
LJOEHILLL
Engine Performance problem
1994 Lincoln Town Car V8 Front Wheel Drive Automatic
Driving on expressway car died w/out warning. Towed home. replaced fuel filter - puel pump. it cranks, but back fires and stalls. What do I need to do?
Jul 1, 2008 at 6:07 PM
DJFINESSE80
  • 34 POSTS
[quote:cc780c1c02="ljoehilll"]Engine Performance problem
Driving on expressway car died w/out warning. Towed home. replaced fuel filter - puel pump. it cranks, but back fires and stalls. What do I need to do?[/quote:cc780c1c02]SOUDS LIKE FIRING ORDER IS OFF, CHECK CHILTON MANUEL FOR FIRING ORDER, WAS THE CAR RECENTLY TUNED UP?CHECK SPARK PLUG WIRES FOR FIRING ORDER, ALSO MAKE SURE ALL PLUGS ARE FIRING, CHECK 1 AT A TIME.HOW? REMOVE WIRE AT ENGINE, 1 AT A TIME, WHEN ENGINE RUNS ERATIC, THERE IS WHERE YOUR PROBLEM IS.CAUTION! UNPLUG WIRE, THEN START ENGINE.SHUT OFF, REPLACE WIRE, THEN REPEAT TO NEXT WIRE.NEVER UNPLUG WIRE WHEN ENGINE IS RUNNING,OR HOLD IN HAND,CARS CAN GIVE OFF 50,000 VOLT OF CURRENT
Jul 30, 2008 at 3:13 AM
