im trying to replace the air bags in the rear. fuse is out and switch in trunk off. airbag is full how do u relieve the pressure?
Mar 11, 2010 at 8:59 PM
BMRFIXIT
CERTIFIED EXPERT
Disconnect electrical connector at air spring solenoid.
Remove air spring solenoid clip.
Rotate solenoid counterclockwise to first stop.
To bleed air from system, pull solenoid straight out slowly to second stop.
After air is completely bled from system, rotate solenoid counterclockwise to third stop and remove from housing.
