My 93 Lincoln Towncar is showing trouble codes in the transmission # 621 Shift Solenoid 1 circuit failure, and code # 622 Shift Solenoid 2 circuit failure, and code # 624 Electronic Pressure Control (EPC) circuit failure and code # 652 Torque Convertor Clutch (TCC) solenoid circuit failure, is it possible for all thes components to go bad at once or do thes codes point back to one component causing the trouble, most of the time the Overdrive light flashes, any information will be greatly appreciated, thanks Dan
Oct 17, 2009 at 2:37 PM
