1992 Lincoln Town Car No pulses to Injectors
1992 LINCOLN TOWN CAR
12,600 MILES • V8 • 2WD • AUTOMATIC
JACOBRAN
Auto stopped running while trying to park & has not started since. You can spray starting ing the throttle body & it its. There is not any pulsae signals on any of the injectors. Tested all 8 with light & meter. Most likely problem???
Dec 8, 2008 at 7:53 AM
BMRFIXIT
  • 19,053 POSTS
I would check for power at the injector
see with key on u should have battery power on the injector connectors
and when cranking PCM will ground and pulse the injectors
check fuses
let me know what is missing
Dec 9, 2008 at 6:30 AM
