Disconnect battery ground cable.
Position transmission selector lever in ``Lo'' position.
Raise and support vehicle, then working from underneath vehicle, disconnect electrical harness from switch by lifting harness straight up off switch.
Using neutral start switch socket tool No. T74P-77247-A or equivalent, remove neutral start switch and O-ring seal by positioning tool over the extension housing area to gain access to switch.
Reverse procedure to install. Torque switch to 7-10 ft. lbs. using tool mentioned above
Jan 13, 2010 at 2:00 AM
