1989 Lincoln Town Car Severe hesitation
1989 LINCOLN TOWN CAR
80,000 MILES • V8 • 2WD • AUTOMATIC
INFAMOUSTK
My son just bought a 89 town car and its beatiful inside and out. The trouble is.....
at idle in park, the throttle responds perfectly with zero hesitation. It idles smooth as silk and shows no roughness at all while in park. Put it in gear though and try to accelorate and it has no get up and go. it doesnt cough or sputter, it just hesitates for twenty seconds or so as it slowly comes up to highway speed. We were told the cat converter is newish....{less than two years}......at highway speeds it runs sweet. But gettin there is way slow. Theres no black smoke as in too rich a mix....in fact thers no smoke at all. I'm stumped on this one. Any helped would be apreciated.
Sep 26, 2010 at 1:36 PM
Hi infamoustk, Welcome to 2carpros and TY for the donation
1989 Lincoln Town Car Severe hesitation could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 26, 2010 at 5:58 PM
