2001 Other Lincoln Models blower motor problems / air suspen
2001 LINCOLN
104,000 MILES • V8 • 2WD • AUTOMATIC
  • 15 POSTS
Nov 15 2009 I posted an intermittent blower problem with this car on this forum & contributed. ALL of the advice / tips / procedures were not correct; I did not need a blower motor, nor a resistor bank, nor a blower switch. What I needed was a "blower control module", which I found out by removing what I was tiold was a switch.
Now I do ned some correct pertinent advice on what to do about an air compressor problem. It cycles repeatedly, sometimes long, sometimes short, sometimes every 5 min sometimes not for 1/2 hr. A pop-off valve releases on top of the compressor everytime before it cycles - does anyone have any idea of what might be causing this? The suspension trouble light only comes on when the car is started & then goes out until the next time the car is started.
Dec 18, 2009 at 6:06 PM
HMAC300
  • 48,601 POSTS
your compressor problem can be anything from a bad compressor/air leak in the system/ bad pop off valve. It needs to be looked at aby a pro to make a decision on what is the best fix.
Feb 23, 2010 at 7:06 PM
