2000 Other Lincoln Models tune up
2000 LINCOLN
70,000 MILES • V8 • 4WD • AUTOMATIC
BONILLA
how to do tune up
Dec 6, 2007 at 6:09 PM
BLACKOP555
  • 10,386 POSTS
first well start off with the fuel system. check over all fuel lines for any damages replace if necessary, then change the fuel filter with a new one.
next take remove one tire at a time and check for wear of the pads and rotors.
next open the hood and take and change and properly gap the spark plugs. then take off one wire from the distributor and spark plug and replace it with a new one, repeat htis for all of them. then take off the distributor cap and rotor and check for wear and carbon build up, replace as neccessary.
Next replace the air filter and PCV filter. also take out the PCV valve and shake it to see if it rattles, if not replace.
next you should check proper fluid levels and chagne the oil. and put some fuel additives in the gas tank and run it.
hope this helps!
Dec 6, 2007 at 8:38 PM
