1974 Other Lincoln Models oil pump
1974 LINCOLN
100,000 MILES • V8 • 2WD • AUTOMATIC
YUKON1981
how do you prime an oil pump
Dec 26, 2009 at 10:45 PM
You need to fabricate a disributor driveshaft like your distributor shaft and hook it up to a drill and prime it thru the distributor hole-or use the starter but disable the ignition system and crank engine over till you see oil up thru the valve train
Dec 26, 2009 at 11:03 PM
