rear differential leak
LINCOLN NAVIGATOR
JHVSPRINCESS
'01 lincoln navigator v-8 2wd with 77,000 I was told I have a small leak in the rear differential. What could cause this? What is the repair work and average cost? :wink:
May 1, 2007 at 8:13 PM
BESTBET777
  • 89 POSTS
where is the leak coming from, could be a bad gaske or bad plug or seal.
May 4, 2007 at 8:15 PM
JHVSPRINCESS
the leak is in the rear; on the center bottom of the large mechanism between the axels. Thanks for taking the time to answer :) I appreciate it.
May 6, 2007 at 6:37 PM
BESTBET777
  • 89 POSTS
Is there a drain plug at the bottom, if so the plug may be loose or stripped, if not the leak is probably coming from a bad gasket.
May 6, 2007 at 7:05 PM
