loud fan noise
LINCOLN NAVIGATOR
FOXKART
I just purchased a 2003 Lincoln aviator with 55000 miles on it. It has a automatic transmission with 2 wheel drive.
The problem is a loud roaring fan noise starts when the outside temperature hits 100 degrees and over. Under that temperature the engine is very quiet and the temperature gage shows normal at all times. The engine never overheats. Do I need to replace the fan clutch or some heat sensor to get rid of this noise.
Engine is a 4.6 v8
My son has the same engine but it is Quiet all the time.
Aug 29, 2007 at 6:05 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like your fan clutch may be too tight if it is loud all the time when it is hot out. Might want to try a new one. Shouldnt be loud all the time
Sep 8, 2007 at 7:39 AM
