2004 Lincoln Navigator Noise on startup
2004 LINCOLN NAVIGATOR
SWOLE
Noises problem
2004 Lincoln Navigator V8 Four Wheel Drive Automatic
I have a 2004 Lincoln Navigator. Whenever I turn it on it makes a loud rattling sound for about three seconds and disappears. Sometimes it ticks but as it warms up it fades. I think the ticking may be a different noise entirely. But that loud rattling noise sounds bad. Sometimes I start the truck and I get no rattle but for the most part if I let it sit for more than 30 minutes it will rattle on startup. I took it to the dealership and paid $80 for a diagnostic check and was told that they did not know what it was. I do not want to take it back in and pay the same so they can tell me the same thing without getting anything resolved. Can anyone help?
Oct 15, 2010 at 9:07 PM
MADMIKE1735
  • 951 POSTS
how is your oil pressure???? these are known for getting buildup on the oil pump screen, and not getting adequate lubrication to the upper end, thus giving the knocking noise your getting.... without removing your oilpan, there is really no way to see if your screen is clogged...
Oct 15, 2010 at 9:09 PM
SWOLE
[quote:b11f4b56e9="madmike1735"]how is your oil pressure???? these are known for getting buildup on the oil pump screen, and not getting adequate lubrication to the upper end, thus giving the knocking noise your getting.... without removing your oilpan, there is really no way to see if your screen is clogged...[/quote:b11f4b56e9]
I'm not sure about the oil pressure but my light is not coming on. The noise I'm getting is not a knocking sound, it's more like a metallic rattling sound for like 3 seconds and then completely disappears.
Oct 15, 2010 at 9:21 PM
TRIOLF01
Did you find out what it was? I am starting to have the same problem with my 2006 Navigator. Thanks
Aug 31, 2012 at 11:36 PM
