#4 is the one closest to the firewall on the passenger side.You will have to move the heater hoses and vacuum lines out of the way to access the coil.It is held down by a 7mm bolt.Once the bolt is out, you just pull the coil up out of the head and install the new one.It is tight back there, so just remove whatever you deem necessary to get at it.I just zip-tie stuff out of the way so as not to unhook anything I dont have to
May 26, 2010 at 12:35 PM
