2001 Lincoln Navigator what do you need
2001 LINCOLN NAVIGATOR
98,000 MILES • V8 • 4WD • AUTOMATIC
JAMES CEURVELS
the question is why do you need a caliper reset tool for the rear break pads what is the diffrence from the rear and the frount how come a c-clamp wont work?
Jun 5, 2009 at 2:41 PM
Are you refering to a tool to twist the caliper back in? If so, that is because the park brake screws out as the brake pads wear. However, I believe you have the park brake behind the rotor. Check and let me know if that is where it is. It will be a small set of brake shoes inside a drum (the rear of the rotor).
Aug 17, 2009 at 11:08 PM
