1st no you didn't tear up the shift motor.
2nd failing to shift out of 4x4 may have gotten your truck to give up trying to get it out of 4x4, disconnect battery to reset.
3rd 4x4 Low shouldn't engage while moving or in drive if I remember correctly.
4th 4x4 can get stuck especially on dry asphalt. Drive in a strait line for a short distance on a flat surface. (Sand or gravel is best) shift to N take your foot off the break let the truck settle break R let it engage then go back to N flip the 4x4 Sw back to AWD/2WD give it 20 seconds to disengage. If that doesn't do it disconnect the battery start it back up sw to n and give it another 20 seconds. If you were on pavement try again or find some sand... the problem is that resistance you feel cornering makes it hard for it to disengage and the computer will give up to avoid burning up the shift motor. If this doesn't work on sand after 2 tries your probably looking at a mechanical or electrical issues not just stuck.
Nov 17, 2019 at 12:51 AM
