1999 Lincoln Navigator Coil #5 getting blown.
1999 LINCOLN NAVIGATOR
148,000 MILES • V8 • 2WD • AUTOMATIC
ARIZONANAV
I get the "Check Engine" light and the diagnostic gives a p0355 for Coil E. I have replaced the coil and plug but light came back on after a long while. Had the coil and plug replaced again, light came back on (much sooner this time) and coil seemed and smelled burnt. Right now I have a new coil but am not driving it. What could be causing the coil to go bad so consistently? Local shop says the "underhood wire harness" needs to be replaced. What to do?
Jul 29, 2008 at 1:17 PM
MERLIN2021
  • 17,250 POSTS
They may be right, or at least part right! You should use an ohm meter and unplug the connector at the coil and at the end of the harness, check the resistance of the same color wires at both ends, one lead at each end, reading should be zero, if higher, you can untape the harness, or run 2 new wires to that injector.
Jul 29, 2008 at 4:52 PM
ARIZONANAV
Can I get this and see if it fixes the problem? Is it the right part or what should I be looking for? It is a MSD Ignition- Dual DIS-4 Harness 88813
https://www.2carpros.com/forum/automotive_pictures/187985_IgnitionWire_1.jpg
http://www.streetsideauto.com/products.asp?lsbYear=1999&lsbMakes=LINCOLN&lsbModels=NAVIGATOR&lsbSubModels=None&lsbEngineSizes=5.4L%20/%20330%20C.I.D.&ParentID=35&SubID=1900&PTID=6122&brand=BCCX&Series=Dual+DIS%2D4+Harness&LookupType=YMM&ResetVQ=True&ResetPQ=True&ResetAPQ=True
Jul 29, 2008 at 5:01 PM
MERLIN2021
  • 17,250 POSTS
Test the wires b4 you replace parts...wireing could be the problem, if it turns out to be the connector, chevy sells the parts.
Jul 29, 2008 at 5:12 PM
