1998 Lincoln Navigator engine shutters, or missfires when a
1998 LINCOLN NAVIGATOR
JAYINAK
Engine Performance problem
1998 Lincoln Navigator V8 Four Wheel Drive Automatic
My truck hesitates when pushing on the gas. And the transmission has a hard time picking gears because of it. I pulled the codes and I have 3DTCs. P0175. P0171.P0174. It shows to lean or to rich in the system but I dont know what the problem is. I also have the freeze frame data on the P0175.
Fuel Sys 1 closed loop, fuel sys 2 NA, Calc Load 48.24, ECT 97,
STFT B1 3.13, LTFT B1 -5.47, STFT B2 2.34, LTFT B2-10.94, engine rpm@1048, vehicle speed@19mph ..well thats about all ive got. hope ya can suggest a problable cause thanx.
Mar 2, 2009 at 9:23 PM
BMRFIXIT
  • 19,053 POSTS
All indicate you have a vacuum leak
check intake for leaks
check MAF sensor
Mar 19, 2009 at 5:59 AM
