1998 Lincoln Navigator driver power seat
1998 LINCOLN NAVIGATOR
153,000 MILES • V8 • AWD • AUTOMATIC
KRAM6900
how does the wiring go for the module under the driver seat it is all unpluged and i am trying to connect them back
May 18, 2009 at 3:05 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Did the motors become unpluged? or wires pulled out of connector? also need to know if memory seat
Let me know
Thanks for donate
May 19, 2009 at 3:04 PM
KRAM6900
IT has a multi function module and on the door there is a #1 and #2 but I think that is for the pedal? Everything was unplugged. When I replaced one of the fuses a 5amp that was blown it blew again so I used a 25 and I hear the motor on the mirror and the light where the 1 and 2 are on the door lit up. I took the fuse back out afraid something was shorting out since the mirror motor wouldnt stop.
May 19, 2009 at 3:21 PM
DOCFIXIT
  • 18,828 POSTS
Little confused How did everthing get unpluged? and why can"t you pulg back together? Did seats change position when the 1-2 switches where pushed?
May 20, 2009 at 10:30 AM
KRAM6900
They were unplugged when we got it. No they did not move when I pushed the 1 2 button I am pretty sure that button is for the pedal.
May 20, 2009 at 11:39 AM
DOCFIXIT
  • 18,828 POSTS
The terminals where most likely removed because of motor shorting out. They should only plug together if it is correct terminal. Do not interchange so I believe there are three so through trial and error you will be able to hook up.
May 20, 2009 at 2:00 PM
