Before any extensive testing, inspect the wire harness inside of the door to body boot. A broken wire or wires here will cause this symptom. It’s common on these vehicles. Another possibility is the window motor, look at the dome light while pressing the window switch to see if it dims when pressing the switch. If it dims, the issue is with the motor.
Apr 24, 2019 at 5:37 PM
