1998 Lincoln Mark VIII Air conditioner
1998 LINCOLN MARK VIII
81,000 MILES • V8 • AWD • AUTOMATIC
DENA
  • 4 POSTS
The alternator regulator went out and we had that fixed. The air was working just fine before this happened. Now it only will blow hot air. The compressor does come on as normal.
What can be the problem? And how do we go about getting it fixed?
Thanks,
Dena
Oct 25, 2008 at 12:45 PM
DOCFIXIT
  • 18,828 POSTS
Run self diagostics simultaneously depress OFF and FLOOR the press AUTO within 2 sec. Display show broken line for 30 sec then codes post codes and will try and solve.
Oct 25, 2008 at 1:21 PM
DENA
  • 4 POSTS
Thank you so much for your help on this. The procedure actually re-set the AC and it now is blowing cold air.
Oct 25, 2008 at 3:09 PM
DOCFIXIT
  • 18,828 POSTS
Glad to have helped when ever power is removed it must be reset. Keep instructions next batt or alt problem you will be able to repair.
Oct 25, 2008 at 3:11 PM
