1996 Lincoln Mark VIII will not start
1996 LINCOLN MARK VIII
KWORLDWIDE
Electrical problem
1996 Lincoln Mark VIII V8 Two Wheel Drive Automatic
i sprayed starting fluid in the intake,will not start,checked the coil no spark.can not find the control module,to test. where is it located at on the vehicle.if that is good,whats next???
Mar 22, 2010 at 9:50 PM
The ignition control module is integrated within the powertrain control module. It is not a separately replaceable component.The Powertrain Control Module is located behind LH side of the instrument panel, on LH side of safety wall.
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 22, 2010 at 10:17 PM
