1996 Lincoln Mark VIII Eleltric Fan motor
1996 LINCOLN MARK VIII
WILLIE.PERRY
Engine Cooling problem
1996 Lincoln Mark VIII V8 Two Wheel Drive Automatic
The fuse to the fan motor is repeatly blows everytime ireplace is and the car run hot. What couse the fuse to blow the fuse may last only afew miles befor it blows(40) amp.
Jun 28, 2008 at 12:25 AM
AIRSOFTSOLDRECN9
  • 348 POSTS
Your blower motor resistor is causing the blower motor to draw too much current. Replace the resistor and see if this fixes your problem. Did you say the car is overheating, or were you refering to the fuse?
Jun 28, 2008 at 2:19 AM
