1995 Lincoln Mark VIII 1995 Lincoln Air Suspension
1995 LINCOLN MARK VIII
102,500 MILES • V8 • 2WD • AUTOMATIC
DESHAWN93
  • 5 POSTS
I am not sure what the problem is, my front end does not drop like its supposed to when it is parked and between 65-70 mph the check air ride warning shows on my message center and then my rear suspension pounds loud, not absorbing bumps in the road. My door ajar sensor stays on but my interior lights go out, heard this can cause the air ride not to function properly, what seems to be the problem?
Apr 29, 2010 at 5:38 PM
BLUECOLLAR
  • 86 POSTS
If the module(brain) doesn't "see" the doors being shut, it will never vent to normal ride height. I would first try to spray some WD-40 on both latches and work them real good. It will most likely fix the problem.
Jul 25, 2010 at 8:57 PM
