A mechanic has checked my air ride system and said that he found no leaks. The problem I am about to relate is more prevalent in cold weather.
When I get in the car sometimes the front end is down, sometimes the back end and sometimes both. When I back out of the garage the front end levels itself and then I get a message "check air ride system". Then, if I shut off the engine and restart it the back end will usually rise to the correct height while I am idling.
Recently, the back end has started to lower itself when I am driving. However, if I can stop, shut off the engine and restart it I can get the back end to rise up. That may fix the issue or it may do it again.
Dec 16, 2008 at 1:03 PM
