1988 Lincoln Mark VII Power steering
1988 LINCOLN MARK VII
130,000 MILES • V8 • 2WD • AUTOMATIC
DAMONSO
Hi, my car has had some problems lately. After I had it in the shop to change the radiator, the CHECK SUSPENSION light came on. It feels like the back right suspension is down. I didn't think it was important. But now the power steering has gone. It makes loud noises when I turn the wheel, and its almost impossible to turn when driving slow. My question is:
Will this be an expensive repair?
Does the two things have something to do with each other (will I need to fix the suspension)?
Thanks!
Feb 24, 2010 at 1:07 AM
BLUECOLLAR
  • 86 POSTS
2 seperate problems.
The air suspension problem is probably leaking air springs. Ford wants $200+ each for air springs, but you can get them for about $80+
The steering problem is a power steering leak. You can fill the reservoir about 3/4 full and turn the wheel back and forth to find where its leaking.
Aug 25, 2010 at 6:09 PM
