83 mark 6 123000 on it ,sometimes it will start and run fine for days other times you go to start it ,it will crank fine but will not start for days then all of asudden you try it it starts and runs fine for afew more days,I have changed everything I can think of from the fuel pump to the brain,the coil,crankshaft position sensor,throttle body throttle position sensor,modlue box-electronic control assembly-map sensor-mlp sensor-timing chain-there was even more I can`t remember,could someone please give me a hint of what I may have missed?? Thanks.
Jan 1, 2007 at 9:24 AM
